Relational concept analysis for circular link key extraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2021
A link key extraction procedure in case of circular dependencies is presented. It uses relational concept analysis and extends the procedure of Deliverable 1.1. This leads to investigate more closely the semantics of relational concept analysis which is given in terms of fixed points. Extracting all fixed points may offer more link key candidates to consider.
elker-1.2.pdf (519.39 Ko) Télécharger le fichier
hal-03501398 , version 1 (23-12-2021)
  • HAL Id : hal-03501398 , version 1
Jérôme Euzenat, Manuel Atencia, Jérôme David, Amedeo Napoli, Jérémy Vizzini. Relational concept analysis for circular link key extraction. [Contract] 1.2, ELKER. 2021, pp.1-57. ⟨hal-03501398⟩
55 Consultations
52 Téléchargements
