A bias-reduced version of the Weissman estimator for extreme value-at-risk - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
One of the most popular risk measures is the Value-at-Risk, which in statistical terms corresponds to the upper $\alpha$-quantile of the distribution where $\alpha \in (0,1)$ is the risk level. We are interested in estimating this risk measure at an extreme level which means when $\alpha$ tends to 0 as the sample size goes to infinity. If the random variable of interest has a heavy-tailed distribution, a common estimator of the Value-at-Risk at extreme levels is the Weissman estimator. The latter is based on two estimators: an order statistic to estimate an intermediate quantile and an estimator of the tail index. The usual practice is to select the same intermediate sequence for both estimators. We show how an adapted choice of two different intermediate sequences leads to a reduction of the asymptotic bias associated with the resulting Weissman estimator. Our approach is compared to other bias-reduced estimators of the extreme Value-at-Risk both on simulations and on a financial real dataset.
Fichier non déposé
hal-03501777 , version 1 (23-12-2021)
  • HAL Id : hal-03501777 , version 1
Jonathan El Methni, Stéphane Girard. A bias-reduced version of the Weissman estimator for extreme value-at-risk. CMStatistics 2021 - 14th International Conference of the ERCIM WG on Computational and Methodological Statistics, Dec 2021, London, United Kingdom. ⟨hal-03501777⟩
34 Consultations
0 Téléchargements
