Ambitropical geometry, hyperconvexity and zero-sum games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Marianne Akian
  • Fonction : Auteur
Stéphane Gaubert
Shapley operators of undiscounted zero-sum two-player games are order-preserving maps that commute with the addition of a constant. We characterize the fixed point sets of Shapley operators, in finite dimension (i.e., for games with a finite state space). Some of these characterizations are of a lattice theoretical nature, whereas some other rely on metric or tropical geometry. More precisely, we show that fixed point sets of Shapley operators are special instances of hyperconvex spaces: they are sup-norm non-expansive retracts, and also lattices in the induced partial order. Moreover, they retain properties of convex sets, with a notion of convex hull defined only up to isomorphism. For deterministic games with finite action spaces, these fixed point sets are supports of polyhedral complexes, with a cell decomposition attached to stationary strategies of the players, in which each cell is an alcoved polyhedron of $A_n$ type. We finally provide an explicit local representation of the latter fixed point sets, as polyhedral fans canonically associated to lattices included in the Boolean hypercube.
hal-03504873 , version 1 (29-12-2021)
Paternité
Marianne Akian, Stéphane Gaubert, Sara Vannucci. Ambitropical geometry, hyperconvexity and zero-sum games. 2023. ⟨hal-03504873⟩
37 Consultations
0 Téléchargements
