Exact quantization of multistage stochastic linear problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We show that the multistage linear problem (MSLP) with an arbitrary cost distribution is equivalent to a MSLP on a finite scenario tree. We establish this exact quantization result by analyzing the polyhedral structure of MSLPs. In particular, we show that the expected cost-to-go functions are polyhedral and affine on the cells of a chamber complex, which is independent of the cost distribution. This leads to new complexity results, showing that MSLP is fixed-parameter tractable.
hal-03504876 , version 1 (30-12-2021)
Maël Forcier, Stéphane Gaubert, Vincent Leclère. Exact quantization of multistage stochastic linear problems. 2021. ⟨hal-03504876⟩
27 Consultations
0 Téléchargements
