Implicit Relaxed All Mach Number Schemes for Gases and Compressible Materials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2023
We present an implicit relaxation scheme for the simulation of compressible flows in all Mach number regimes based on a Jin–Xin relaxation approach. The main features of the proposed scheme lie in its simplicity and effectiveness. Thanks to the linearity of the flux in the relaxation system, the time semidiscrete scheme can be reformulated in linear decoupled elliptic equations resulting in the same number of unknowns as in the original system. To obtain the correct numerical diffusion in all Mach number regimes, a convex combination of upwind and centered fluxes is applied. The numerical scheme is validated by applying it on a model for nonlinear elasticity. Simulations of gas and fluid flows, as well as deformations of compressible solids are carried out to assess the performance of the numerical scheme in accurately approximating material waves in different Mach regimes.
hal-04375656 , version 1 (30-12-2021)
hal-04375656 , version 2 (05-01-2024)
Andrea Thomann, Angelo Iollo, Gabriella Puppo. Implicit Relaxed All Mach Number Schemes for Gases and Compressible Materials. SIAM Journal on Scientific Computing, 2023, 45 (5), pp.A2632-A2656. ⟨10.1137/21M146819X⟩. ⟨hal-04375656v2⟩
Collections
CNRS INRIA INRIA2
63 Consultations
0 Téléchargements
