Binary Graph Descriptor for Robust Relocalization on Heterogeneous Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2022
In this paper, we propose a novel binary graph descriptor to improve loop detection for visual SLAM systems. Our contribution is twofold: i) a graph embedding technique for generating binary descriptors which conserve both spatial and histogram information extracted from images; ii) a generic mean of combining multiple layers of heterogeneous data into the proposed binary graph descriptor, coupled with a matching and geometric checking method. We also introduce an implementation of our descriptor into an incremental Bag-of-Words (iBoW) structure that improves efficiency and scalability, and propose a method to interpret Deep Neural Network (DNN) results. We evaluate our system on synthetic and real datasets across different lighting and seasonal conditions. The proposed method outperforms state-of-the-art loop detection frameworks in terms of relocalization precision and computational performance, as well as displays high robustness against cross-condition datasets.
2022-RAL_Wang.pdf (5.69 Mo) Télécharger le fichier
hal-03506034 , version 1 (10-01-2022)
Xi Wang, Marc Christie, Eric Marchand. Binary Graph Descriptor for Robust Relocalization on Heterogeneous Data. IEEE Robotics and Automation Letters, 2022, 7 (2), pp.2008 - 2015. ⟨10.1109/LRA.2022.3142854⟩. ⟨hal-03506034⟩
113 Consultations
199 Téléchargements
