DEISA: dask-enabled in situ analytics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Julien Bigot
Bruno Raffin
A widening performance gap is separating CPU performance and IO bandwidth on large scale systems. In some fields such as weather forecast and nuclear fusion, numerical models generate such amounts of data that classical post hoc processing is not feasible anymore due to the limits in both storage capacity and IO performance. In situ approaches are attractive to bypass disk accesses in these cases and fully leverage the HPC platform. They are however often complex to set up and can require to re-develop parallel versions of the analysis from scratch. In this paper we propose a hybrid model that is well suited for in situ workflows that combine regular simulations and irregular analytics. Our model couples the bulk synchronous parallel paradigm for simulation with a distributed task-based one for analysis. This reduces complexity and leverages the best of each of these two powerful paradigms. We validate the model with a prototype, called DEISA, that supports coupling MPI parallel codes with analyses written using Dask. This implementation requires minimal modifications of both the simulation and analysis codes compared to their post hoc counterpart. It give access to an already existing rich ecosystem to be used in situ such as the parallel versions of Numpy, Pandas and scikit-learn. Experiments in configurations up to 1024 cores show that DEISA can improve the simulation wallclock time (excluding analysis) by a factor up to 3 and the total experiment (including analysis) hour.core cost by a factor of up to 5 compared to parallel post hoc with plain Dask while requiring the modification of only two lines of python code, three of YAML, and none at all in a C simulation code already instrumented with PDI Data Interface
HiPC__DEISA__Dask_Enabled_In_Situ_Analytics.pdf (273.43 Ko) Télécharger le fichier
hal-03509198 , version 1 (04-01-2022)
  • HAL Id : hal-03509198 , version 1
Amal Gueroudji, Julien Bigot, Bruno Raffin. DEISA: dask-enabled in situ analytics. HiPC 2021 - 28th International Conference on High Performance Computing, Data, and Analytics, Dec 2021, virtual, India. pp.1-10. ⟨hal-03509198⟩
451 Consultations
357 Téléchargements
