A comprehensive static modeling methodology via beam theory for compliant mechanisms - Archive ouverte HAL Access content directly
Journal Articles Mechanism and Machine Theory Year : 2022
(1, 2) , (1, 2)
1
2
Compliant Mechanisms (CMs) present several desired properties for mechanical applications only depending on elastic deformation of the involved compliant beams/flexures. As reported in the current literature, most CM designs utilize straight beams and initially curved beams (ICBs) as the fundamental flexible members. In CM research community, many great contributions regarding modeling these elementary flexible members have been achieved. In this paper, a comprehensive modeling methodology, based on beam theory, has been established to characterize the static planar deflection of slender beam. Then such a methodology has been applied to solve 8 loading scenarios of large beam-deflection problems that exist in the design of CMs. Essentially speaking, all these beam-deflection problems are treated as a type of boundary value problems (BVPs) of an ordinary differential equation (ODE) and solved by a modified collocation method. After that, this methodology has been used to model some representative CMs with large-deflection strokes, such as compliant parallelograms.
Embargoed file
Embargoed file
0 10 23
Year Month Jours
Avant la publication
Dates and versions
hal-03513497 , version 1 (29-12-2022)
Attribution - NonCommercial - NoDerivatives - CC BY 4.0
Identifiers
Cite
Ke Wu, Gang Zheng. A comprehensive static modeling methodology via beam theory for compliant mechanisms. Mechanism and Machine Theory, In press, 169, pp.104598. ⟨10.1016/j.mechmachtheory.2021.104598⟩. ⟨hal-03513497⟩
0 View
0 Download
Share
