Categorical Functional Data Analysis. The cfda R Package - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics Année : 2021
Categorical functional data represented by paths of a stochastic jump process with continuous time and a finite set of states are considered. As an extension of the multiple correspondence analysis to an infinite set of variables, optimal encodings of states over time are approximated using an arbitrary finite basis of functions. This allows dimension reduction, optimal representation, and visualisation of data in lower dimensional spaces. The methodology is implemented in the cfda R package and is illustrated using a real data set in the clustering framework.
hal-03515152 , version 1 (06-01-2022)
Cristian Preda, Quentin Grimonprez, Vincent Vandewalle. Categorical Functional Data Analysis. The cfda R Package. Mathematics , 2021, 9 (23), pp.31. ⟨10.3390/math9233074⟩. ⟨hal-03515152⟩
35 Consultations
0 Téléchargements
