Reducing FTM ranging and location attack exposure with crowd-wisdom - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
802.11 Fine Timing Measurement is an indoor ranging technique. Because it is unauthenticated and unprotected, an adversary can implement ranging and location attacks, by inserting one or more rogue responders and causing an unsuspecting client to incorporate forged values into its location computation. We show in this paper that protection intended for attacks on comparable ranging techniques, like GPS, are ineffective in the case of FTM. However, we also show that a crowd-sourcing technique that confirms that one AP is known by the others can mitigate the attack exposure.
Reducing_FTM_Attack_with_Crowd_sourcing_IPIN__final_.pdf (1.1 Mo) Télécharger le fichier
hal-03515297 , version 1 (06-01-2022)
Paternité
  • HAL Id : hal-03515297 , version 1
Jerome Henry, Yann Busnel, Romaric Ludinard, Nicolas Montavont. Reducing FTM ranging and location attack exposure with crowd-wisdom. IPIN 2021: 9th International Conference on Indoor Positioning and Indoor Navigation, Nov 2021, Lloret de Mar, Spain. pp.1-16. ⟨hal-03515297⟩
81 Consultations
107 Téléchargements
