DRL-based Slice Placement under Realistic Network Load Conditions - Archive ouverte HAL Access content directly
Conference Papers Year :
(1, 2) , (1) , (3) , (2)
1
2
3
Amina Boubendir
  • Function : Author
  • PersonId : 1080196
Fabice Guillemin
  • Function : Author
  • PersonId : 1080198
Pierre Sens
We propose to demonstrate a network slice placement optimization solution based on Deep Reinforcement Learning (DRL), referred to as Heuristically-controlled DRL, which uses a heuristic to control the DRL algorithm convergence. The solution is adapted to realistic networks with large scale and under non-stationary traffic conditions (namely, the network load). We demonstrate the applicability of the proposed solution and its higher and stable performance over a non-controlled DRL-based solution. Demonstration scenarios include full online learning with multiple volatile network slice placement request arrivals.
Demo_CNSM_2021.pdf (810.17 Ko) Télécharger le fichier
Dates and versions
hal-03516310 , version 1 (07-01-2022)
Identifiers
  • HAL Id : hal-03516310 , version 1
Cite
Jose Jurandir Alves Esteves, Amina Boubendir, Fabice Guillemin, Pierre Sens. DRL-based Slice Placement under Realistic Network Load Conditions. CNSM 2021 - 17th International Conference on Network and Service Management, Oct 2021, Izmir, Turkey. ⟨hal-03516310⟩
32 View
46 Download
Share
