Abduction inELvia Translation to FOL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a technique for performing TBox abduction in the description logic EL. The input problem is converted into first-order formulas on which a prime implicate generation technique is applied, then EL hypotheses are reconstructed by combining the generated positive and negative implicates.
paper2.pdf (782.58 Ko) Télécharger le fichier
hal-03516691 , version 1 (01-02-2022)
  • HAL Id : hal-03516691 , version 1
Fajar Haifani, Patrick Koopmann, Sophie Tourret. Abduction inELvia Translation to FOL. SOQE 2021 - 2nd Workshop on Second-Order Quantifier Elimination and Related Topics, Nov 2021, Hanoï (online), Vietnam. pp.46-58. ⟨hal-03516691⟩
75 Consultations
37 Téléchargements
