LP Based Bounds for Cesàro and Abel Limits of the Optimal Values in Non-ergodic Stochastic Systems - Archive ouverte HAL Access content directly
Conference Papers Year : 2021
(1) , (2) , (2)
1
2
In this paper, we study asymptotic properties of problems of control of stochastic discrete time systems with time averaging and time discounting optimality criteria, and we establish that the Cesàro and Abel limits of the optimal values in such problems can be estimated with the help of a certain infinite-dimensional (ID) linear programming (LP) problem and its dual.
20210405-ecc_draft-1.pdf (258.33 Ko) Télécharger le fichier
Dates and versions
hal-03517927 , version 1 (09-01-2022)
Identifiers
Cite
Konstantin Avrachenkov, Vladimir Gaitsgory, Lucas Gamertsfelder. LP Based Bounds for Cesàro and Abel Limits of the Optimal Values in Non-ergodic Stochastic Systems. ECC 2021 - European Control Conference, Jun 2021, Delft, Netherlands. pp.2444-2449, ⟨10.23919/ECC54610.2021.9655136⟩. ⟨hal-03517927⟩
21 View
40 Download
Share
