Extrapolated DIscontinuity Tracking for complex 2D shock interactions
A new shock-tracking technique that avoids re-meshing the computational grid around the moving shock-front was recently proposed by the authors [1]. This paper describes further algorithmic improvements which make the extrapolated Discontinuity Tracking Technique (eDIT) capable of dealing with complex shock-topologies featuring shock-shock and shock-wall interactions. Various test-cases are included to describe the key features of the methodology and prove its order-of-convergence properties.
