Geospatial Knowledge in Housing Advertisements: Capturing and Extracting Spatial Information from Text - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Information of the geographical and spatial type is found in numerous text documents and constitutes a very challenging target for extraction. Geoparsing applications have been developed to extract geographic terms. However, off-the-shelf Named Entity Recognition (NER) models are mainly designed for Toponym recognition and are very sensitive to language specificity. In this paper, we propose a workflow to first extract geographic and spatial entities based on a BiLSTM-CRF architecture with a concatenation of several text representations. We also propose a Relation Extraction module, particularly aimed at spatial relationships extraction, to build a structured Geospatial knowledge base. We demonstrate our pipeline by applying it to the case of French housing advertisements, which generally provide information about a property's location and neighbourhood. Our results show that the workflow tackles French language and the variability and irregularity of housing advertisements, generalizes Geoparsing to all geographic and spatial terms, and successfully retrieves most of the relationships between entities from the text.
kcap-paper.pdf (510.05 Ko) Télécharger le fichier
hal-03518717 , version 1 (10-01-2022)
Lucie Cadorel, Alicia Blanchi, Andrea G. B. Tettamanzi. Geospatial Knowledge in Housing Advertisements: Capturing and Extracting Spatial Information from Text. K-CAP 2021 - International Conference on Knowledge Capture, Dec 2021, Virtual Event USA, United States. pp.41-48, ⟨10.1145/3460210.3493547⟩. ⟨hal-03518717⟩
118 Consultations
307 Téléchargements
