Using Grammar-Based Genetic Programming for Mining Subsumption Axioms Involving Complex Class Expressions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ontology enrichment is a key task in the area of the Semantic Web. It allows directly to enrich the links between entities of the semantic Web and thus adding information. Our research area is part of this objective with the search for axioms using an evolutionary process. We propose an adaptation resulting from the coupling between evolutionary algorithms and the theory of possibilities in order to allow the research of axioms of subsumption composed of complex classes.
Web_Intelligence_2021___CAMERA_READY.pdf (775.17 Ko) Télécharger le fichier
hal-03519365 , version 1 (10-01-2022)
Rémi Felin, Andrea G. B. Tettamanzi. Using Grammar-Based Genetic Programming for Mining Subsumption Axioms Involving Complex Class Expressions. WI-IAT 2021 - 20th IEEE/WIC/ACM International Conference on Web Intelligence and Intelligent Agent Technology, Dec 2021, Melbourne, Australia. ⟨10.1145/3486622.3494025⟩. ⟨hal-03519365⟩
80 Consultations
72 Téléchargements
