Link Adaptive Protocol for V2LC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Meysam Mayahi
  • Fonction : Auteur
  • PersonId : 1122565
Valeria Loscri
  • Fonction : Auteur
  • PersonId : 1084587
Antonio Costanzo
  • Fonction : Auteur
  • PersonId : 1026791
As the Visible Light Communications (VLC) is growing up, it is not restricted anymore to the traditional indoor applications such as LiFi or positioning, but it finds new customers at outdoor vendors like underwater and vehicle applications. In this paper we looked at VLC challenges in Vehicular Communications from Medium Access Control point of view. We proposed Link Adaptive Protocol where a single handshake association and fast handover algorithms prolong VLC connectivity. Moreover, adaptive modulation has been suggested in order to increase the throughput. Simulation results show the link adaptive protocol outperforms slotted-aloha in outage probability and goodput, properly achieving a trade-off between pilot rate and protocol efficiency.
Link adaptive protocol for V2LC.pdf (611.92 Ko) Télécharger le fichier
hal-03519701 , version 1 (10-01-2022)
Meysam Mayahi, Valeria Loscri, Antonio Costanzo. Link Adaptive Protocol for V2LC. IoL 2021 - Internet of Lights, Jun 2021, New York, Virtual, United States. pp.13-17, ⟨10.1145/3469264.3469807⟩. ⟨hal-03519701⟩
Collections
INRIA INRIA2
22 Consultations
46 Téléchargements
