Usability Study of Learning-Based Pose Estimation of Industrial Objects from Synthetic Depth Data
For visual assistance systems deployed in an industrial setting, precise object pose estimation is an important task in order to support scene understanding and to enable subsequent grasping and manipulation. Industrial environments are especially challenging since mesh-models are usually available while physical objects are not or are expensive to model. Manufactured objects are often similar in appearance, have limited to no textural cues and exhibit symmetries. Thus, these are especially challenging for recognizers that are meant to provide detection, classification and pose estimation on instance level. A usability study of a recent synthetically trained learning-based recognizer for these particular challenges is conducted. Experiments are performed on the challenging T-LESS dataset due to its relevance for industry.
Informatique [cs]
