Estimation of 3D geometrical properties of spheroid-like particle systems using projection images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a parametric method to estimate geometrical properties of a population of spheroid-like particles from 2D projection images. The method consists in, first, detecting the projection of the particles in the images, and then estimating the parameters of the supposed probability laws of the spheroids semi-axes using a Bayesian framework. Moreover, a new estimator of the Sauter mean diameter to assess the efficiency of two-phase flow processes, in the case of spheroid-like particle system, is proposed. Still in view to its practical use for the characterization of two-phase flows, the whole methodology is applied to a typical bubbly flow.
deLanglard_ISIVC2020.pdf (3.26 Mo) Télécharger le fichier
cea-03516334 , version 1 (07-01-2022)
Mathieu de Langlard, Fabrice Lamadie, Sophie Charton, Johan Debayle. Estimation of 3D geometrical properties of spheroid-like particle systems using projection images. ISIVC INTERNATIONAL SYMPOSIUM ON SIGNAL, IMAGE, VIDEO AND COMMUNICATIONS, Mines Saint-Etienne, Apr 2021, Saint-Etienne, France. pp.1-6, ⟨10.1109/ISIVC49222.2021.9487552⟩. ⟨cea-03516334⟩
132 Consultations
53 Téléchargements
