Dynamical Synapses in Retinal Surprise coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2021
• Stimulation a dissected retina with a sequence of periodic dark flashes • Extracellular spike recordings. 2. Identification of necessary components via pharmacological inhibition of synaptic transmission onto : • ON bipolar cells via mGluR6 receptor antagonist LAP-4. • OFF bipolar cells via AMPA receptor antagonist ACET. Results ON BC inhibition cancels the OSR.
Neuromod_Poster_v4.pdf (1.3 Mo) Télécharger le fichier
hal-03521429 , version 1 (11-01-2022)
  • HAL Id : hal-03521429 , version 1
Simone Ebert, Semihchan Sermet, Thomas Buffet, Bruno Cessac, Olivier Marre. Dynamical Synapses in Retinal Surprise coding. Neuromod Inaurguration Day, Mar 2021, online, France. ⟨hal-03521429⟩
62 Consultations
29 Téléchargements
