Leveraging in-network real-value computation for home network device recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current generation of switches are highly programmable and able to support stateful. However, these switches cannot perform floating point operations. As a result several network applications have to be run on external servers or middleboxes in the network. We introduce InREC, a system that extends the capabilities of programmable switches to support in-network real-valued operations using the IEEE half-precision floating point representation. Our demo on a Barefoot Tofino switches demonstrates the efficiency of InREC for in-network computation by computing a logistic regression function to classify devices (IoT and laptop) in a simulated home environment.
InRec_demo.pdf (175.9 Ko) Télécharger le fichier
hal-03525070 , version 1 (13-01-2022)
  • HAL Id : hal-03525070 , version 1
Matthews Jose, Kahina Lazri, Jérôme François, Olivier Festor. Leveraging in-network real-value computation for home network device recognition. IM 2021 - IFIP/IEEE International Symposium on Integrated Network Management (Demo), May 2021, Bordeaux / Virtual, France. ⟨hal-03525070⟩
39 Consultations
24 Téléchargements
