Experiments and Modelling of Seismoelectrics in the Ultrasonic Range: A Comparison With Electrokinetic Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Acoustical wave propagation in a fluid-filled porous media creates electromagnetic (EM) disturbances through a physical process referred in the literature as seismoelectric (SE) conversion. Two EM fields result from this conversion, one accompanies the seismic wave in the form of a transient electric field and the other is generated at interfaces and propagates independently with an electromagnetic wave behaviour. The latter has an arguably high potential of application in near-surface exploration, possibly comparable to other indirect EM methods. In what follows, an experimental setup conceived to measure both SE fields mentioned above was employed in the study of a porous saturated homogeneous medium with (1) and without (2) a thin layer inside. It was seen that measuring absolute potentials is more efficient for detecting the EM-wave generated at interfaces than using electric fields estimated from measured potential differences. Using a numerical code and an experimental source, the measured data was compared with the modelling showing there is a fair agreement between experiments and electrokinetic theory. Our results are promissing and open the path for a more in depth investigation of the SE conversion phenomena and its relation with physical properties.
Fichier non déposé
hal-03525950 , version 1 (14-01-2022)
Victor Martins Gomes, Daniel Brito, Stéphane Garambois, Clarisse Bordes, Hélène Barucq. Experiments and Modelling of Seismoelectrics in the Ultrasonic Range: A Comparison With Electrokinetic Theory. NSG2021 27th European Meeting of Environmental and Engineering Geophysics, Aug 2021, [Hybrid], France. pp.1-5, ⟨10.3997/2214-4609.202120159⟩. ⟨hal-03525950⟩
80 Consultations
0 Téléchargements
