An iterative clustering algorithm for the Contextual Stochastic Block Model with optimality guarantees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Guillaume Braun
  • Fonction : Auteur
  • PersonId : 1089525
Hemant Tyagi
  • Fonction : Auteur
  • PersonId : 1087784
Christophe Biernacki
  • Fonction : Auteur
  • PersonId : 923939
Real-world networks often come with side information that can help to improve the performance of network analysis tasks such as clustering. Despite a large number of empirical and theoretical studies conducted on network clustering methods during the past decade, the added value of side information and the methods used to incorporate it optimally in clustering algorithms are relatively less understood. We propose a new iterative algorithm to cluster networks with side information for nodes (in the form of covariates) and show that our algorithm is optimal under the Contextual Symmetric Stochastic Block Model. Our algorithm can be applied to general Contextual Stochastic Block Models and avoids hyperparameter tuning in contrast to previously proposed methods. We confirm our theoretical results on synthetic data experiments where our algorithm significantly outperforms other methods, and show that it can also be applied to signed graphs. Finally we demonstrate the practical interest of our method on real data.
CSBM_Braun21.pdf (1.45 Mo) Télécharger le fichier
hal-03526257 , version 1 (14-01-2022)
Guillaume Braun, Hemant Tyagi, Christophe Biernacki. An iterative clustering algorithm for the Contextual Stochastic Block Model with optimality guarantees. Proceedings of the 39th International Conference on Machine Learning, Jul 2022, Baltimore, United States. ⟨hal-03526257⟩
177 Consultations
69 Téléchargements
