A pose independent method for accurate and precise body composition from 3D optical scans - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Obesity Année : 2021
Michael Wong
Bennett Ng
Isaac Tian
Sima Sobhiyeh
Ian Pagano
Andrea Garber
Gertraud Maskarinec
Sergi Pujades
Steven Heymsfield
John Shepherd
Objective: To investigate if digitally reposing three-dimensional optical (3DO) whole-body scans to a standardized pose would improve body composition accuracy and precision regardless of initial pose. Methods: Healthy adults (n=540), stratified by sex, BMI, and age, completed whole-body 3DO and dual-energy X-ray absorptiometry (DXA) scans in the Shape Up! Adults study. The 3DO mesh vertices were represented with standardized templates and a low-dimensional space by principal component analysis (stratified by sex). Total sample was split into a training (80%) and test (20%) set for both males and females. Stepwise linear regression was used to build prediction models for body composition and anthropometry outputs using 3DO principal components (PCs). Results: The analysis included 472 participants after exclusions. After reposing, three PCs described 95% of the shape variance in the male and female training sets. 3DO body composition accuracy compared to DXA was: fat mass R2 = 0.91 male, 0.94 female; fat-free mass R2 = 0.95 male, 0.92 female; visceral fat mass R2 = 0.77 male, 0.79 female. Conclusions: Reposed 3DO body shape PCs produced more accurate and precise body composition models that may be used in clinical or nonclinical settings when DXA is unavailable or when frequent ionizing radiation exposure is unwanted.
Wong-T-pose.pdf (512.54 Ko) Télécharger le fichier
hal-03528084 , version 1 (17-01-2022)
Michael Wong, Bennett Ng, Isaac Tian, Sima Sobhiyeh, Ian Pagano, et al.. A pose independent method for accurate and precise body composition from 3D optical scans. Obesity, 2021, 29 (11), pp.1835-1847. ⟨10.1002/oby.23256⟩. ⟨hal-03528084⟩
82 Consultations
219 Téléchargements
