Subformula Linking for Intuitionistic Logic with Application to Type Theory - Archive ouverte HAL Access content directly
Conference Papers Year : 2021
Abstract Subformula linking is an interactive theorem proving technique that was initially proposed for (classical) linear logic. It is based on truth and context preserving rewrites of a conjecture that are triggered by a user indicating links between subformulas, which can be done by direct manipulation, without the need of tactics or proof languages. The system guarantees that a true conjecture can always be rewritten to a known, usually trivial, theorem. In this work, we extend subformula linking to intuitionistic first-order logic with simply typed lambda-terms as the term language of this logic. We then use a well known embedding of intuitionistic type theory into this logic to demonstrate one way to extend linking to type theory.
paper39_hal.pdf (386.32 Ko) Télécharger le fichier
Dates and versions
hal-03528659 , version 1 (18-01-2022)
Identifiers
Cite
Kaustuv Chaudhuri. Subformula Linking for Intuitionistic Logic with Application to Type Theory. CADE 2021 - 28th International Conference on Automated Deduction, Jul 2021, Pittsburgh, PA (Virtual), United States. pp.200-216, ⟨10.1007/978-3-030-79876-5_12⟩. ⟨hal-03528659⟩
37 View
47 Download
Share
