High-order multigrid strategies for HHO discretizations of elliptic equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Linear Algebra with Applications Année : 2022
This study compares various multigrid strategies for the fast solution of elliptic equations discretized by the Hybrid High-Order method. Combinations of h-, p-and hp-coarsening strategies are considered, combined with diverse intergrid transfer operators. Comparisons are made experimentally on 2D and 3D test cases, with structured and unstructured meshes, and with nested and non-nested hierarchies. Advantages and drawbacks of each strategy are discussed for each case to establish simplified guidelines for the optimization of the time to solution.
High_order_multigrid_strategies_for_HHO.pdf (686.73 Ko) Télécharger le fichier
hal-03531293 , version 1 (18-01-2022)
hal-03531293 , version 2 (19-05-2022)
Daniele Di Pietro, Pierre Matalon, Paul Mycek, Ulrich Rüde. High-order multigrid strategies for HHO discretizations of elliptic equations. Numerical Linear Algebra with Applications, 2022, 30 (1), pp.e2456. ⟨10.1002/nla.2456⟩. ⟨hal-03531293v2⟩
118 Consultations
120 Téléchargements
