Deep Reinforcement Learning for L3 Slice Localization in Sarcopenia Assessment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sarcopenia is a medical condition characterized by a reduction in muscle mass and function. A quantitative diagnosis technique consists of localizing the CT slice passing through the middle of the third lumbar area (L3) and segmenting muscles at this level. In this paper, we propose a deep reinforcement learning method for accurate localization of the L3 CT slice. Our method trains a reinforcement learning agent by incentivizing it to discover the right position. Specifically, a Deep Q-Network is trained to find the best policy to follow for this problem. Visualizing the training process shows that the agent mimics the scrolling of an experienced radiologist. Extensive experiments against other state-of-the-art deep learning based methods for L3 localization prove the superiority of our technique which performs well even with a limited amount of data and annotations.
MLMI_2021_camera_ready.pdf (350.72 Ko) Télécharger le fichier
hal-03532954 , version 1 (18-01-2022)
Othmane Laousy, Guillaume Chassagnon, Edouard Oyallon, Nikos Paragios, Marie-Pierre Revel, et al.. Deep Reinforcement Learning for L3 Slice Localization in Sarcopenia Assessment. Machine Learning in Medical Imaging @MICCAI, Sep 2021, Strasbourg, France. pp.317-326, ⟨10.1007/978-3-030-87589-3_33⟩. ⟨hal-03532954⟩
90 Consultations
129 Téléchargements
