Non-selfadjoint perturbation of the semiclassical magnetic Laplacian - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This article is devoted to the spectral analysis of the electromagnetic Schrödinger operator on the Euclidean plane. In the semiclassical limit, we derive a pseudo-differential effective operator that allows us to describe the spectrum in various situations and appropriate regions of the complex plane. Not only results of the selfadjoint case are proved (or recovered) in the proposed unifying framework, but new results are established when the electric potential is complex-valued. In such situations, when the non-selfadjointness comes with its specific issues (lack of a "spectral theorem", resolvent estimates), the analogue of the "low-lying eigenvalues" of the selfadjoint case are still accurately described and the spectral gaps estimated.
MRV22.pdf (599.89 Ko) Télécharger le fichier
hal-03533719 , version 1 (18-01-2022)
hal-03533719 , version 2 (25-01-2022)
  • HAL Id : hal-03533719 , version 1
Léo Morin, Nicolas Raymond, San Vu Ngoc. Non-selfadjoint perturbation of the semiclassical magnetic Laplacian. 2022. ⟨hal-03533719v1⟩
98 Consultations
90 Téléchargements
