Assimilation of Images via Dictionary Learning-Based Sparsity Regularization Strategy: An Application for Retrieving Fluid Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Geoscience and Remote Sensing Année : 2022
In this work, we propose a structure sparsity regularization strategy in the framework of 4-D variational data assimilation (4-D Var). In meteorology and oceanography, the number of unknown model variables is far fewer than that of image observations, often leading to solve an underdetermined nonlinear inverse problem. In recent years, the ℓ¹-norm-based sparsity regularization approach has attracted great attention in the field of 4-D Var because of its data structure preservation and noise suppression. To avoid little underlying physical priors considered, we introduce a widely used dictionary learning (DL) method to adaptively derive an efficient sparse approximation via learning a basis from a given dataset. For our target application of estimating sea surface flows, we consider a DL sparsity constraint on the variable of flow vorticity due to its rich spatial variation related to flows evolution. A novel anisotropic regularization method combined with fluid dynamics characteristics could overcome magnitude underestimation and staircase artifacts appearing in the gradient regularization-based 4-D Var method. The split Bregman iteration with fast convergence property is employed to solve the ℓ¹+ℓ² nonsmooth minimization problem. The promising fluid flows estimation performance in real test cases (assimilation of image sequences collected from CORIOLIS experimental turntable) demonstrates the efficiency of our approach.
Fichier non déposé
hal-03534164 , version 1 (19-01-2022)
Long Li, Jianwei Ma, Francois-Xavier Le Dimet, Arthur Vidard. Assimilation of Images via Dictionary Learning-Based Sparsity Regularization Strategy: An Application for Retrieving Fluid Flows. IEEE Transactions on Geoscience and Remote Sensing, 2022, 60, pp.5907120:1-20. ⟨10.1109/TGRS.2021.3110799⟩. ⟨hal-03534164⟩
63 Consultations
0 Téléchargements
