Programming and verifying real-time design using logical time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Robert de Simone
Damien Chabrol
  • Fonction : Auteur
  • PersonId : 1123759
Amira Methni
The design of embedded control software calls for stringent real-time constraints. For that, formalisms and theories based on the notion of logical time give abstraction of real-time durations that are usually not known at design level. Comparison between synchronous languages, Logical Execution Time (LET) and the PsyC language can be fruitful, in our case, with the goal of empowering the industrial language PsyC, which is close to LET, with (logical) time and functional verification methods inspired from synchronous languages.
FDL21_paper_30.pdf (118.12 Ko) Télécharger le fichier
hal-03537976 , version 1 (21-01-2022)
  • HAL Id : hal-03537976 , version 1
Fabien Siron, Dumitru Potop-Butucaru, Robert de Simone, Damien Chabrol, Amira Methni. Programming and verifying real-time design using logical time. FDL 2021 - Forum on specification & Design Languages, Sep 2021, Antibes, France. ⟨hal-03537976⟩
133 Consultations
85 Téléchargements
