Large-Scale Unsupervised Object Discovery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Existing approaches to unsupervised object discovery (UOD) do not scale up to large datasets without approximations that compromise their performance. We propose a novel formulation of UOD as a ranking problem, amenable to the arsenal of distributed methods available for eigenvalue problems and link analysis. Through the use of self-supervised features, we also demonstrate the first effective fully unsupervised pipeline for UOD. Extensive experiments on COCO and OpenImages show that, in the single-object discovery setting where a single prominent object is sought in each image, the proposed LOD (Large-scale Object Discovery) approach is on par with, or better than the state of the art for medium-scale datasets (up to 120K images), and over 37% better than the only other algorithms capable of scaling up to 1.7M images. In the multi-object discovery setting where multiple objects are sought in each image, the proposed LOD is over 14% better in average precision (AP) than all other methods for datasets ranging from 20K to 1.7M images. Using self-supervised features, we also show that the proposed method obtains state-of-the-art UOD performance on OpenImages. Our code is publicly available at https://github.com/huyvvo/LOD.
hal-03541587 , version 1 (24-01-2022)
Huy V. Vo, Elena Sizikova, Cordelia Schmid, Patrick Pérez, Jean Ponce. Large-Scale Unsupervised Object Discovery. NeurIPS - Thirty-fifth Conference on Neural Information Processing Systems, Dec 2021, Virtual, Canada. ⟨hal-03541587⟩
34 Consultations
0 Téléchargements
