Unconditional bound-preserving and energy-dissipating finite-volume schemes for the Cahn-Hilliard equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Computational Physics Année : 2023
We propose finite-volume schemes for the Cahn-Hilliard equation that unconditionally and discretely satisfy the boundedness of the phase field and the free-energy dissipation. Our numerical framework is applicable to a variety of free-energy potentials including the Ginzburg-Landau and Flory-Huggins, general wetting boundary conditions and degenerate mobilities. Its central thrust is the finite-volume upwind methodology, which we combine with a semi-implicit formulation based on the classical convex-splitting approach for the free-energy terms. Extension to an arbitrary number of dimensions is straightforward thanks to their cost-saving dimensional-splitting nature, which allows to efficiently solve higher-dimensional simulations with a simple parallelization. The numerical schemes are validated and tested in a variety of prototypical configurations with different numbers of dimensions and a rich variety of contact angles between droplets and substrates.
hal-03541875 , version 1 (24-01-2022)
Rafael Bailo, José Carrillo, Serafim Kalliadasis, Sergio Perez. Unconditional bound-preserving and energy-dissipating finite-volume schemes for the Cahn-Hilliard equation. Communications in Computational Physics, 2023, 34 (3), pp.713-748. ⟨10.4208/cicp.OA-2023-0049⟩. ⟨hal-03541875⟩
55 Consultations
0 Téléchargements
