An online Minorization-Maximization algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modern statistical and machine learning settings often involve high data volume and data streaming, which require the development of online estimation algorithms. The online Expectation-Maximization (EM) algorithm extends the popular EM algorithm to this setting, via a stochastic approximation approach. We show that an online version of the Minorization-Maximization (MM) algorithm, which includes the online EM algorithm as a special case, can also be constructed in a similar manner. We demonstrate our approach via an application to the logistic regression problem and compare it to existing methods.
main.pdf (677.87 Ko) Télécharger le fichier
hal-03542180 , version 1 (25-01-2022)
  • HAL Id : hal-03542180 , version 1
Hien Duy Nguyen, Florence Forbes, Gersende Fort, Olivier Cappé. An online Minorization-Maximization algorithm. 17th Conference of the International Federation of Classification Societies, Jul 2022, Porto, Portugal. ⟨hal-03542180⟩
226 Consultations
329 Téléchargements
