MRI field strength predicts Alzheimer's disease: a case example of bias in the ADNI data set - Archive ouverte HAL Access content directly
Conference Papers Year :
The Alzheimer's Disease Neuroimaging Initiative (ADNI) data set has been extensively used for the prediction of the progression of prodromal patients to Alzheimer's disease dementia. However, the deep learning community is not always aware of the biases that may contaminate neuroimaging data sets, which may lead to flawed results. In this case example, we demonstrated how ignoring the magnetic resonance (MR) field strength can bias performance of deep learning prediction when using MR images as input. Finally, we discussed options to overcome this problem.
ISBI_2022___ADNI_field_strength_BIAS.pdf (130.69 Ko) Télécharger le fichier
Dates and versions
hal-03542213 , version 1 (25-01-2022)
Identifiers
Cite
Elina Thibeau-Sutre, Baptiste Couvy-Duchesne, Didier Dormont, Olivier Colliot, Ninon Burgos. MRI field strength predicts Alzheimer's disease: a case example of bias in the ADNI data set. ISBI 2022 - International Symposium on Biomedical Imaging, Mar 2022, Kolkata, India. ⟨10.1109/ISBI52829.2022.9761504⟩. ⟨hal-03542213⟩
206 View
151 Download
Share
