Derivation and numerical approximation of two-temperature Euler plasma model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2021
This paper gives a derivation of the two-temperature Euler plasma system from the two-fluid MHD model. The two-temperature Euler plasma system is proved to be an asymptotic regime for weakly magnetized plasma of the two-fluid MHD model. Our procedure is more general, enabling us to show that assumptions in previous derivations in literature are straightforward consequences of our work. We then propose a finite volume approximation to compute the solution of the two-temperature Euler plasma model in unstructured tessellations used to adequately mesh the toroidal geometry of the tokamak, where flows the plasma. Numerical tests illustrate our method.
TiTeEGS.pdf (7.78 Mo) Télécharger le fichier
hal-03543365 , version 1 (26-01-2022)
Afeintou Sangam, Élise Estibals, Hervé Guillard. Derivation and numerical approximation of two-temperature Euler plasma model. Journal of Computational Physics, 2021, 444, pp.48. ⟨10.1016/j.jcp.2021.110565⟩. ⟨hal-03543365⟩
77 Consultations
131 Téléchargements
