ct: control toolbox - Numerical tools and examples in optimal control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Combining direct and indirect methods to have the best of both worlds is an efficient method to solve numerically optimal control problems. A direct solver will typically provide information on the structure of the optimal control, allowing an educated guess for indirect shooting. The control toolbox ct offers such possibilities and is presented on two examples. The first example has a bang-singular solution and is solved by chaining direct and indirect solvers. The second one consists in computing conjugate and cut loci on an ellipsoid of revolution, which is performed using a more advanced combination of indirect methods with differential continuation.
cao-2022c.pdf (541.9 Ko) Télécharger le fichier
hal-03558975 , version 1 (05-02-2022)
hal-03558975 , version 2 (24-06-2022)
Jean-Baptiste Caillau, Olivier Cots, Pierre Martinon. ct: control toolbox - Numerical tools and examples in optimal control. Proceedings of 18th IFAC Workshop on Control Applications of Optimization, Jul 2022, Paris, France. pp.13-18, ⟨10.1016/j.ifacol.2022.08.074⟩. ⟨hal-03558975v2⟩
374 Consultations
321 Téléchargements
