TactJam: An End-to-End Prototyping Suite for Collaborative Design of On-Body Vibrotactile Feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present TactJam, an end-to-end suite for creating and sharing low fidelity prototypes of on-body vibrotactile feedback. With Tac-tJam, designers can create, record and share vibrotactile patterns online. This opens up new ways of collaboratively designing vibrotactile patterns both in collocated as well as in remote settings. We evaluate TactJam in a two-part distributed online workshop, exploring the design of on-body tactons. Participants were able to successfully use TactJam to learn about tacton design. We present an overview of mappings between tactons and their associated concepts before comparing the results of tactons created using solely a GUI and tactons created through experimenting with placements directly on the body. Conducting both parts of the workshop separately highlighted the importance of designing directly with bodies: less implicit assumptions were made, and designs were guided by personal experience. We reflect on these results and close on deliberations for the future development of TactJam.
tactjam.pdf (5.52 Mo) Télécharger le fichier
hal-03564266 , version 1 (10-02-2022)
Dennis Wittchen, Katta Spiel, Bruno Fruchard, Donald Degraen, Oliver Schneider, et al.. TactJam: An End-to-End Prototyping Suite for Collaborative Design of On-Body Vibrotactile Feedback. Proceedings of the 16th International Conference on Tangible, Embedded, and Embodied Interaction (TEI 2022), Feb 2022, Daejeon, South Korea. pp.1-13, ⟨10.1145/3490149.3501307⟩. ⟨hal-03564266⟩
58 Consultations
17 Téléchargements
