TAG: Learning Timed Automata from Logs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Event logs are often one of the main sources of information to understand the behavior of a system. While numerous approaches have extracted partial information from event logs, in this work, we aim at inferring a global model of a system from its event logs. We consider real-time systems, which can be modeled with Timed Automata: our approach is thus a Timed Automata learner. There is a handful of related work, however, they might require a lot of parameters or produce Timed Automata that either are undeterministic or lack precision. In contrast, our proposed approach, called TAG, requires only one parameter and learns a deterministic Timed Automaton having a good tradeoff between accuracy and complexity of the automata. This allows getting an interpretable and accurate global model of the real-time system considered. Our experiments compare our approach to the related work and demonstrate its merits.
TAG_Learning_Timed_Automata_from_Logs.pdf (320.61 Ko) Télécharger le fichier
hal-03564455 , version 1 (11-02-2022)
  • HAL Id : hal-03564455 , version 1
Lénaïg Cornanguer, Christine Largouët, Laurence Rozé, Alexandre Termier. TAG: Learning Timed Automata from Logs. AAAI 2022 - 36th AAAI Conference on Artificial Intelligence, Feb 2022, Virtual, Canada. pp.1-9. ⟨hal-03564455⟩
181 Consultations
323 Téléchargements
