On change of measure inequalities for $f$-divergences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We propose new change of measure inequalities based on $f$-divergences (of which the Kullback-Leibler divergence is a particular case). Our strategy relies on combining the Legendre transform of $f$-divergences and the Young-Fenchel inequality. By exploiting these new change of measure inequalities, we derive new PAC-Bayesian generalisation bounds with a complexity involving $f$-divergences, and holding in mostly unchartered settings (such as heavy-tailed losses). We instantiate our results for the most popular $f$-divergences.
2202.05568.pdf (249.21 Ko) Télécharger le fichier
hal-03573465 , version 1 (14-02-2022)
Antoine Picard-Weibel, Benjamin Guedj. On change of measure inequalities for $f$-divergences. 2022. ⟨hal-03573465⟩
55 Consultations
270 Téléchargements
