Numerical investigation of solitary wave stability for quantum dissipative systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Physics Année : 2021
We consider a simple model describing the interaction of a quantum particle with a vibrational environment, which eventually acts as a friction on the particle. This equation admits soliton-like solutions, and we numerically investigate their stability when subjected to a small initial impulsion. Our findings illustrate the analogies with the behavior of classical particles and the relevance of asymptotic models.
Fichier non déposé
hal-03577474 , version 1 (16-02-2022)
Thierry Goudon, Léo Vivion. Numerical investigation of solitary wave stability for quantum dissipative systems. Journal of Mathematical Physics, 2021, 62 (1), pp.011509. ⟨10.1063/5.0021246⟩. ⟨hal-03577474⟩
40 Consultations
0 Téléchargements
