Symbolic-Numeric Factorization of Differential Operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Factorisation Symbolique-Numérique d'Opérateurs Différentiels
We present a symbolic-numeric Las Vegas algorithm for factoring Fuchsian ordinary differential operators with rational function coefficients. The new algorithm combines ideas of van Hoeij's "local-to-global" method and of the "analytic" approach proposed by van der Hoeven. It essentially reduces to the former in "easy" cases where the local-to-global method succeeds, and to an optimized variant of the latter in the "hardest" cases, while handling intermediate cases more efficiently than both.
issac22.pdf (304.95 Ko) Télécharger le fichier
hal-03580658 , version 1 (18-02-2022)
hal-03580658 , version 2 (18-05-2022)
hal-03580658 , version 3 (31-05-2022)
hal-03580658 , version 4 (02-06-2022)
Frédéric Chyzak, Alexandre Goyer, Marc Mezzarobba. Symbolic-Numeric Factorization of Differential Operators. 2022. ⟨hal-03580658v2⟩
246 Consultations
226 Téléchargements
