Larger Corner-Free Sets from Combinatorial Degenerations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
There is a large and important collection of Ramsey-type combinatorial problems, closely related to central problems in complexity theory, that can be formulated in terms of the asymptotic growth of the size of the maximum independent sets in powers of a fixed small (directed or undirected) hypergraph, also called the Shannon capacity. An important instance of this is the corner problem studied in the context of multiparty communication complexity in the Number On the Forehead (NOF) model. Versions of this problem and the NOF connection have seen much interest (and progress) in recent works of Linial, Pitassi and Shraibman (ITCS 2019) and Linial and Shraibman (CCC 2021). We introduce and study a general algebraic method for lower bounding the Shannon capacity of directed hypergraphs via combinatorial degenerations, a combinatorial kind of "approximation" of subgraphs that originates from the study of matrix multiplication in algebraic complexity theory (and which play an important role there) but which we use in a novel way. Using the combinatorial degeneration method, we make progress on the corner problem by explicitly constructing a corner-free subset in $F_2^n \times F_2^n$ of size $\Omega(3.39^n/poly(n))$, which improves the previous lower bound $\Omega(2.82^n)$ of Linial, Pitassi and Shraibman (ITCS 2019) and which gets us closer to the best upper bound $4^{n - o(n)}$. Our new construction of corner-free sets implies an improved NOF protocol for the Eval problem. In the Eval problem over a group $G$, three players need to determine whether their inputs $x_1, x_2, x_3 \in G$ sum to zero. We find that the NOF communication complexity of the Eval problem over $F_2^n$ is at most $0.24n + O(\log n)$, which improves the previous upper bound $0.5n + O(\log n)$.
hal-03581653 , version 1 (20-02-2022)
Paternité
Matthias Christandl, Omar Fawzi, Hoang Ta, Jeroen Zuiddam. Larger Corner-Free Sets from Combinatorial Degenerations. ITCS 2022 - 13th Innovations in Theoretical Computer Science Conference, Jan 2022, Berkeley, United States. pp.1-2410, ⟨10.4230/LIPIcs.ITCS.2022.48⟩. ⟨hal-03581653⟩
66 Consultations
0 Téléchargements
