Which Pattern for a Low Pattern-Induced Bias? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2022
Benoît Blaysat
Michel Grédiac
  • Fonction : Auteur
  • PersonId : 1038622
The first objective of this presentation is to show that it is possible to explain the cause of the pattern-induced bias (PIB) observed in displacement fields obtained by local DIC. A model is presented for this purpose. It gathers the different errors made when retrieving this displacement by minimizing the optical residual over subsets. It is shown that PIB predicted with this model and its counterpart observed with displacement fields obtained with DIC are in good agreement. When DIC is applied on periodic patterns like checkerboards instead of random speckles, it is observed that PIB becomes negligible. Such regular patterns are however not well suited for DIC. Hence it is recalled how to process such images by minimizing the optical residual in the Fourier domain instead of the spatial one. PIB is assessed in this case, and it is also observed that PIB is negligible in displacement maps obtained with such regular patterns processed by minimizing the optical residual in the Fourier domain.
Fichier non déposé
hal-03585479 , version 1 (23-02-2022)
Frédéric Sur, Benoît Blaysat, Michel Grédiac. Which Pattern for a Low Pattern-Induced Bias?. Sharlotte L.B. Kramer, Rachael Tighe, Ming-Tzer Lin, Cosme Furlong, Chi-Hung Hwang. Thermomechanics & Infrared Imaging, Inverse Problem Methodologies, Mechanics of Additive & Advanced Manufactured Materials, and Advancements in Optical Methods & Digital Image Correlation, Volume 4, Springer International Publishing, pp.103-105, 2022, Conference Proceedings of the Society for Experimental Mechanics Series, ⟨10.1007/978-3-030-86745-4_15⟩. ⟨hal-03585479⟩
55 Consultations
0 Téléchargements
