Minimizing travelling waves for the Gross-Pitaevskii equation on $\mathbb{R} \times \mathbb{T}$
We study the Gross-Pitaevskii equation in dimension two with periodic conditions in one direction, or equivalently on the product space $ \mathbb{R} \times \mathbb{T}_L$ where $L > 0$ and $\mathbb{T}_L = \mathbb{R} / L \mathbb{Z}$. We focus on the variational problem consisting in minimizing the Ginzburg-Landau energy under a fixed momentum constraint. We prove that there exists a threshold value for L below which minimizers are the one-dimensional dark solitons, and above which no minimizer can be one-dimensional.
Minimizing_travelling_waves_Gross-Pitaevskii.pdf (555.03 Ko)
Télécharger le fichier
