Geometric design of friction ring dampers in blisks using nonlinear modal analysis and Kriging surrogate model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Structural and Multidisciplinary Optimization Année : 2022
Integrally bladed disks (blisk) have been widely used in the turbo-machinery industry due to its high aerodynamic performance and structural efficiency. A friction ring damper (FRD) is usually integrated in the system to improve its low damping. However, the design of the geometry of this FRD become complex and computationally expensive due to the strong nonlinearities from friction interfaces. In this work, we propose an efficient modelling strategy based on advanced nonlinear modal analysis and Kriging surrogate models to design and optimize the geometry of a 3D FRD attached to a high fidelity full-scale blisk. The 3D ring damper is parametrised with a few key geometrical parameters. The impact of each geometric parameter and their sensitivities to nonlinear dynamic response can be efficiently assessed using Kriging meta-modelling based on a few damped nonlinear normal modes. Results demonstrate that the damping performances of ring dampers can be substantially optimized through the proposed modelling strategy whilst key insights for the design of the rings are given. It is also demonstrated that the distribution of the contact normal load on the contact interfaces has a strong influence on the damping performances and can be effectively tuned via the upper surface geometry of the ring dampers.
Sun2022_Article_GeometricDesignOfFrictionRingD.pdf (5.84 Mo) Télécharger le fichier
hal-03591512 , version 1 (28-02-2022)
Paternité
Yekai Sun, Enora Denimal, Jie Yuan, Loïc Salles. Geometric design of friction ring dampers in blisks using nonlinear modal analysis and Kriging surrogate model. Structural and Multidisciplinary Optimization, 2022, 65 (3), pp.98. ⟨10.1007/s00158-021-03093-w⟩. ⟨hal-03591512⟩
52 Consultations
52 Téléchargements
