Adaptive control of a simple nonlinear system without a priori information on the plant parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 1992
The authors present an adaptive control scheme for nonlinear systems of the form x=c*/sup T/f(x)+b*u, where f(x) is Lipschitz, c* is a constant vector, and b* is a constant scalar. The control scheme achieves asymptotical model matching without a priori knowledge of the sign of the b* gain. The adaptive scheme is free from singularities in the sense that the estimate of b*, entering in the denominator of the control law, is bounded away from zero. The singularity has been overcome through a suitable modification of the parameter estimates which is based on standard least squares covariance matrix properties.
RLBB_AC_TAC1192.pdf (4.65 Mo) Télécharger le fichier
hal-03592572 , version 1 (08-03-2022)
Rogelio Lozano, Bernard Brogliato. Adaptive control of a simple nonlinear system without a priori information on the plant parameters. IEEE Transactions on Automatic Control, 1992, 37 (1), pp.30-37. ⟨10.1109/9.109636⟩. ⟨hal-03592572⟩
62 Consultations
42 Téléchargements
