Reproduction of Human Demonstrations with a Soft-Robotic Arm based on a Library of Learned Probabilistic Movement Primitives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we introduce a novel technique that aims to control a two-module bio-inspired soft-robotic arm in order to qualitatively reproduce human demonstrations. The main idea behind the proposed methodology is based on the assumption that a complex trajectory can be derived from the composition and asynchronous activation of learned parameterizable simple movements constituting a knowledge base. The present work capitalises on recent research progress in Movement Primitive (MP) theory in order to initially build a library of Probabilistic MPs (ProMPs), and subsequently to compute on the fly their proper combination in the task space resulting in the requested trajectory. At the same time, a model learning method is assigned with the task to approximate the inverse kinematics, while a replanning procedure handles the sequential and/or parallel ProMPs' asynchronous activation. Taking advantage of the mapping at the primitive-level that the ProMP framework provides, the composition is transferred into the actuation space for execution. The proposed control architecture is experimentally evaluated on a real soft-robotic arm, where its capability to simplify the trajectory control task for robots of complex unmodeled dynamics is exhibited.
Oikonomou2022_ICRA_preprint.pdf (3.07 Mo) Télécharger le fichier
hal-03593923 , version 1 (02-03-2022)
  • HAL Id : hal-03593923 , version 1
Paris Oikonomou, Athanasios Dometios, Mehdi Khamassi, Costas Tzafestas. Reproduction of Human Demonstrations with a Soft-Robotic Arm based on a Library of Learned Probabilistic Movement Primitives. 2022 IEEE International Conference on Robotics and Automation (ICRA 2022), May 2022, Philadelphia, PA, United States. ⟨hal-03593923⟩
128 Consultations
116 Téléchargements
