Growth-fragmentation model for a population presenting heterogeneity in growth rate: Malthus parameter and long-time behavior - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
The goal of the present paper is to explore the long-time behavior of the growth-fragmentation equation formulated in the case of equal mitosis and variability in growth rate, under fairly general assumptions on the coefficients. The first results concern the monotonicity of the Malthus parameter with respect to the coefficients. Existence of a solution to the associated eigenproblem is then stated in the case of a finite set of growth rates thanks to Kreȋn-Rutman theorem and a series of estimates on moments. Afterwards, adapting the classical general relative entropy (GRE) method enables us to ensure uniqueness of the eigenelements and derive the long-time asymptotics of the Cauchy problem. We prove convergence towards the steady state including in the case of individual exponential growth known to exhibit oscillations at large times in absence of variability. A few numerical simulations are eventually performed in the case of linear growth rate to illustrate our monotonicity results and the fact that variability, providing enough mixing in the heterogeneous population, is sufficient to re-establish asynchronicity.
paper.pdf (1.42 Mo) Télécharger le fichier
hal-03598346 , version 1 (04-03-2022)
  • HAL Id : hal-03598346 , version 1
Anaïs Rat, Magali Tournus. Growth-fragmentation model for a population presenting heterogeneity in growth rate: Malthus parameter and long-time behavior. 2022. ⟨hal-03598346⟩
219 Consultations
148 Téléchargements
