A new vessel-based method to estimate automatically the position of the non-functional fovea on altered retinography from maculopathies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
In pathological fundus images with maculopathies, the fovea position is usually located using Normative Anatomical Measures (NAM). This simple method relies on two conditions: that images are acquired under standard testing conditions (primary head position and central fixation) and that the optic disk is entirely visible on the image. However, these two conditions are not always met in the case of maculopathies, especially during fixation tasks. Here, we propose a new Vessel-Based Fovea Localization (VBFL) approach.
Arvo2022_foveaLocalization.pdf (26.79 Ko) Télécharger le fichier
Calabrese-et-al_2022.pdf (72.92 Mo) Télécharger le fichier
hal-03600375 , version 1 (07-03-2022)
  • HAL Id : hal-03600375 , version 1
Aurelie Calabrese, Vincent Fournet, Severine Dours, Frédéric Matonti, Eric Castet, et al.. A new vessel-based method to estimate automatically the position of the non-functional fovea on altered retinography from maculopathies. ARVO 2022 - Annual Meeting Association for Research in Vision and Ophthalmology, May 2022, Denver, United States. ⟨hal-03600375⟩
116 Consultations
40 Téléchargements
