Estimation of regional pulmonary compliance in idiopathic pulmonary fibrosis based on personalized lung poromechanical modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Biomechanical Engineering Année : 2022
Cécile Patte
Pulmonary function is tightly linked to the lung mechanical behavior, especially large deforma-tion during breathing. Interstitial lung diseases, such as Idiopathic Pulmonary Fibrosis (IPF), havean impact on the pulmonary mechanics and consequently alter lung function. However, IPF re-mains poorly understood, poorly diagnosed and poorly treated. Currently, the mechanical impactof such diseases is assessed by pressure-volume curves, giving only global information. We de-veloped a poromechanical model of the lung that can be personalized to a patient based on routineclinical data. The personalization pipeline uses clinical data, mainly CT-images at two time stepsand involves the formulation of an inverse problem to estimate regional compliances. The estima-tion problem can be formulated both in terms of “effective”, i.e., without considering the mixtureporosity, or “rescaled”, i.e., where the first-order effect of the porosity has been taken into account,compliances. Regional compliances are estimated for one control subject and three IPF patients,allowing to quantify the IPF-induced tissue stiffening. This personalized model could be used in theclinic as an objective and quantitative tool for IPF diagnosis.
pneuestim-clean.pdf (2.71 Mo) Télécharger le fichier
hal-03605865 , version 1 (11-03-2022)
Cécile Patte, Pierre-Yves Brillet, Catalin Fetita, Jean Francois Bernaudin, Thomas Gille, et al.. Estimation of regional pulmonary compliance in idiopathic pulmonary fibrosis based on personalized lung poromechanical modeling. Journal of Biomechanical Engineering, 2022, 144 (9), pp.091008:1-091008:14. ⟨10.1115/1.4054106⟩. ⟨hal-03605865⟩
142 Consultations
241 Téléchargements
